It’s clearly coming out of the protective boot around the drive shaft on the drivers side, but a similar color and consistency fluid can be found on the passenger side on the underside of the hood.
I don’t lose a noticeable amount of motor oil or PS fluid in between oil changes, and I empty/refill the PS reservoir with each oil change.
What fluid am I losing, and where do you think it’s leaking from?
