I copied a previous post from back in 2006 about what oil to use in small engines, and I think it ought to be a sticky for anyone trying to decide what type of oil to use. I'm with the rest of you here, I love to read, speculate, prognosticate and generally over think this oil situation. Then, luckily, when it actually comes time to change oil, my common sense kicks in and I use a more sensible choice. Just give it a read, and see if you can't agree with Bror Jace, he's made some very well thought out posts about this very topic. All of this is not to say that synthetic is not a great oil, probably the best, but and it's a big but, if you perform frequent maintenance, then it's not needed. Cost is probably the same, more frequent cheaper oil changes as opposed to less often more expensive maintenance. But for me, and apparently Bror Jace, we like to maintain our stuff more often and keep fresh fluids in them. If you don't want to do that much maintenance, the I implore you to use the best syn you can afford.
Here's the post from 2006, and I think it's probably the best written one on the subject.
"For OPE (Outdoor Power Equipment) I prefer to change the oil fairly frequently (we have about 10 pieces, I change the oil in half each year) so I like to use the very affordable HDEOs which also are great at preventing wear, keeping the motor's internals clean and have a high TBN ... ideal for motors that are stored with the same oil for 6+ months at a time.
And I don't really want to use the same 5W-30 I use in my Sentra SpecV 2.5L (Schaeffer 5W-30 and/or Chevron 5W-30). The stuff thins out (by design) and isn't quite as good as a HDEO for the things I mentioned above.
My big point above was that single weights simply aren't needed anymore. They are made in smaller batches so are often over-priced and usually you get the skimpiest add-pack the manufacturer/blender uses in its entire line. Plus, I some can even accelerate wear on cool-morning starts (below 40F).
I think the synthetics (especially true PAO-types) can be great in these applications. I just try to get by with a cheaper oil I can change more often. [I dont know]
Oh, and my detached garage can get down to below 0F in the dead of winter [Eek!] ... although I rarely let it get much below 20F before I get the wood stove going. [Wink]
For that reason, I will be switching our Ariens snowblower with a Tecumshe 11.5hp Sno-King motor over to Rotella 5W-40 next change. I would have preferred Chevron Delo 0W-30 ... but just try and find the stuff. [Roll Eyes]"
