From what I understand, Mobil's Drive Clean oil uses a group 1 base, at least in 10w30 and 5w30 form. It's got a great additive package that allows it to meet the SL specs.quote:
Originally posted by Ken:
Is there any API-SL oil on the market made from Group I base oil? Isn't higher spec base stock required to meet these specs?
Ken
I thought so too, but I called Mobil and was told group III for the 5w-20. I was very surprised as it doesn't have great specs. If I was told correctly, this must make Mobil Drive Clean 5w-20 the cheapest "synthetic".quote:
Originally posted by HOndaGuy:
I thought mobil drive clean 5w20 was group 1 or 2 basestocks?
But the most likely scenario in the event of mechanical damage inside the engine is that the maker will stonewall you and you'll be forced to try to prove that your actions didn't cause the damage. I know, it's backwards, but the maker has a bigger legal budget and longer time to drag this out.quote:
Originally posted by rpn453:
Alright, here's my view on the whole thing:
Using a different grade of oil will not void your warranty unless Ford proves that using a different oil was the cause of the engine failure
What ?quote:
Have a look at the viscosities of various motor oils. They have differing viscosities at 100 deg C, but a 15W-50 will have the same viscosity at 100 deg C as a 5W-20 will have at a slightly lower temperature. [/QB]
Not making light of possible warranty concerns, but if you verify through oil analysis that a 5w30 has lower wear numbers, oxidation, and nitration than a 5w20 (or vice versa) you can be assured of success with the grade and brand of oil. It will also give you ammunition in a a warranty dispute.quote:
You're not far wrong. Motor oil viscosity varies exponentially with temperature change. I plotted Motorcraft's 5w-20 and Mobil 1 15w-50 on an SAE viscosity vs temp chart and the 5w-20 has the same viscosity at about 70*C (158*F) as the 15w-50 at 100*C.quote:
Esso Superflo, for example:
The 5W-20 has a viscosity of 47 cSt at 40 deg. C. By interpolation, I would guess the viscosity is 20 cSt at about 85 deg. C (probably more like 80 though since it's not perfectly linear?).
The 5W-50 has a viscosity of 17 cSt at 100 deg. C. This is only a 20 degree temperature difference between similar viscosities. Even on the highway, my car (based on coolant temperature) has variations of more than 30 deg. C when outside temperatures vary between -40 deg. C to 40 deg. C at the extremes we get (when I'm using the same thermostat). I would imagine the oil temps vary accordingly.
I'm not trying to come off like I think I'm an expert though, so correct me if I'm wrong.
