2003 Ford Ranger Vulcan 3.0 Ltr V6
I have been trying to decide what viscosity of oil to use and have been doing some research at this site and elsewhere. Ford of course specs 5W-20. I did and posted a 3700 mile Factory Fill UOA (5W-20) and a 7,900 mile with Amsoil 0W-30 UOA. The lead count on the factory fill was 98 while on the second UOA it was 14, high compared to other UOA's?? In my research at BITOG I came across a great thread by MotorBike on 4/30/04 "Understanding of Bearing Metalurgy in Different Engines. A search of Ford engine specs gives these specifications for the bearings of a 2004 V6, but I bet the 2003 is the same (could not find 03):
Camshaft - Relaceable Bushing, Steel Backed, Babbitt, (What's in Babbitt?)
Main Bearings - Replaceable Insert, Aluminum
Connecting Rod Bearings, Aluminum
So where's all my lead coming from?
I understand when a manufacturer specs an oil it is expected to run in all conditions world wide. So I was thinking that a 5W-30 in North Carolina might work OK, give better wear protection and start-up and reduce the lead given the little higher viscosity?? But where is this lead coming from? This also lead into another question, How do manufacturers design engines to use a specific viscosity of oil? I've read here that european cars can spec 0W-40 or 5W-40. Are these higher viscosities a result of bearing materials, bearing clearances, higher oil pressure, hotter running temps?
[ May 29, 2004, 08:17 AM: Message edited by: needtoknow ]
