Well, it was 78° and humid
here in NYC today
The A/C was just
okay
I have a procedure for this, considering I have little A/C experience, and only driveway grade tools
1. Wash the condenser
2. Evaporator refresh kit (kinda washes the evaporator?)
3. New cabin filter
4. Evaluate cooling fan/belt drive/blower motor functionality
Two bolts and some clips whips the grille and horns out of the way
I didn't feel like pulling the bumper
$5 can of coil cleaner dislodged some dirt, but it wasn't too bad
Lots of rinsing and back flushing to clear it all out
Take for an extended drive to dry the condenser out, as when wet it'll perform better, skewing gauge readings
All other components checked out, but even during extended highway operation on MAX AC, the temp would go no lower than 48°
No bueno
After you've done all those steps, then and only then do you consider touching the A/C charge
There's a place in hell for the AC Pro™ can
Took for an extended drive to eliminate heat load, then installed a gauge set
These pressure's didn't look bad at all, and the compressor/fans were on constantly
I was looking for 35-45 and 150-170 based on 75° Ambient
These numbers can vary slightly due to humidity
I inverted a partly used can of 134a, purged the charge hose, and charged in 3 second bursts ON THE LOW SIDE
Close low side, let system stabilize
Bring RPMs up, check vent temp
Rinse and repeat
Brought the low side up to ~45ish, and the high side to ~175ish
Now it would cycle every few minutes, vent temperatures dropped, and evaporator condensation output increased significantly
Now it was a 12oz partly used can, and there's still some left in it
I'm estimating I only put in 3-6oz
...on a system that holds 17.2 oz, that means quite a bit
But now I get 38° to 42° out the vents, in around town traffic
Closed the can, sucked in the residual in the hose, recapped service ports
It's gonna be warmer this week, so that'll be a real test of performance, but as of today it was keeping me more than comfortable
For a $5 can of cleaner, and a $7 can of 134a, I'm calling that a win
I also found some leftover TSB intermediate shaft grease from my Camry, seems to have taken some of the clunk out of the steering column
78° of humidity outside, 38° of comfort in bumper to bumper inside
Next week hopefully the O² sensor spacer arrives, and I can get to the exhaust shop and get the leak repaired
Looks good clean
I'm gonna give the headlight polish another go
It'd look mint if it wasn't for the hood
