Originally Posted By: Hokiefyd
Originally Posted By: gathermewool
How much torque do you think a 190# man can apply, bouncing with all my weight on an OEM lug wrench? I'd guess that I conservatively put twice the spec'd torque, easily.
Depending on the length of the OEM lug wrench, you were probably applying less torque than you realize. Torque is measured in force x distance. In the case of a torque wrench, "force" is your mass acted upon by gravity (aided with muscle if you brace yourself against something) and "distance" is how far away from the fulcrum (socket) you are.
Many OEM lug wrenches are relatively short. Say your wrench is 14" long (1.2'). Say you can also get half of your weight onto the end of the wrench (95 lb). If so, you'd have been applying 114 lb*ft on the socket. If you apply the same amount of weight on a 2' bar, then you've got 195 lb*ft on the socket. You probably couldn't truly get all of your weight on the end of the wrench, even if it felt like it. Half of your weight is probably a reasonable guess, but who knows. Either way, it sounds like they truly were put on by a gorilla.
If it's common that you're NOT the last person to install the lug nuts (so you're sure that they're not over-tightened), then I recommend keeping a long breaker bar or a ratchet and cheater bar in the spare tire well, loaded with the correct socket of course.
I couldn't loosen ANY OF THE LUGS, STANDING ON THE OEM LUG WRENCH!!!
You must have missed this part
The OEM lug wrench in question is 11" from tip to centerline of the socket. I stood with my full weight, as far out on the bar as possible, so a good conservative estimate for the lever arm would probably be 10" (though the centerline of my foot was probably, realistically right at the end of the bar.
10in. X 1ft/12in. X 190# = 158.33 ft-lbs
This is the static torque. I was squatting and rising while standing on the OEM lug wrench, increasing the maximum torque by some factor due to my downward momentum and then upward force while rising from the squatted position.
I wouldn't be surprised if I was apply upwards of 200 ft-lbs of torque.
Also, I appreciate your post, but I'm a pretengineer by trade, and while I'm certainly not the sharpest tool in the shed, I at least understand the concept of torque
