And it was not pretty...
First of all, the gunky, dark areas you see on the AF surface, imagine that twice thick and covering the WHOLE surface almost. When I took it out it was like that, and I dropped it on the floor, so I never took a pic of the REAL state it was in. NOT like in the pics below. These pics were taken AFTER most of the gunk layer has fallen off due to me dropping the old AF on the floor AND then throwing it in in the trash.
I took it out of the trash can to find some spots (see Pics) that still had a bit of gunk/dust attached, but it only gives a small idea of what it really was.
This AF i believe, has been in the car for 10 yrs / 42k miles probably. IDK why I never changed it before...
The reason I took it out again for pics is:
some of you might have seen my thread about a cyl misfire CEL on the car. Well today I pulled plugs on coil packs while car was running and determined it's NOT a coil pack. Since this started i had erased code, but car has been weak and low on power.
THEN I changed the AF. Installed a new one and went for a drive (really to get gas, for which i have to get on the hwy to get to the Shell station).
THE CAR WAS BACK ON FULL POWER LIKE BEFORE THE MISFIRE / CEL EPISODE. !!
This is NOT my imagination, I know the roads and spots so well where the car was hesitating and couldn't get uphill. Now it FLEW uphill !
Two people from BMW forums i know (and one from bitog) saw the pics and think that it could well have been the state of AF and that it could have starved car of air and screwed up the A/F ratio enough to cause a temporary misfire and cause all symptoms the car had.
Now the PICS - tell me what you think: could THIS (imagine the WHOLE AF surface like the worst area you see and multiply by 2 or 3) restrict air that much? if not, it's a really weird coincidence...
