If you look at all the UOA's on this website so far, generally speaking, from 0 to 6k miles I don't think there is hardly any differnce between many oils in well running engines. Look at the variances we see in wear #'s and we see highs and lows with all oils depending on the condition of the engine.
I think it makes sense then to focus on other benefits of engine oils, that are over looked, such as Coefficient of friction, hot/cold temp. performance and how well the oil will keep an engine clean. Take performance cars. You could run Castrol GTX and Pennzoil and achieve similar wear to Mobil 1 and Amsoil in a hot running Vette or WRX. We've seen cheaper oils give better wear #'s then M1. However, after a good 5 or 6k miles of fairly hard driving, I'd think that the deposit control of the M1/Amsoil would be much better and the engine would be much cleaner. I'd also think that the transfer of engine heat would be much better with a good synthetic, which is true in many cases.
As I've mentioned before, my friend has lowerd his engine temps. by 15-20F using S2k Amsoil. So rather then getting hung up of 8ppm of Pb vs 3ppm, to me is not as important as these other aspects of oils. One of the main problems we see on here are dirty engines that need Rx. We don't see engines wearing out as far as I know. I don't really here to many people saying "my car died bc my engine wore out". Just a few updated thoughts.
[ November 17, 2003, 09:10 PM: Message edited by: buster ]
![[Wink]](images/icons/wink.gif)
