Is quality dino/synthetic with quality oil filter ( wix/purolator...) can handle 5k or 6 months OCI on all driving condition now ? because I was bore and checking UOA section, and most I see blackstone recommend is over 5k miles some I see 7k miles.
Most manufacturers are at least 5K, unless they state to follow life meters. Mine is usually around 6K miles, (OLM) assume calibrated for conventional.
I have successfully converted friends and family to 5000k though they are skittish. Me personally I am a believer in 5000 to 7500k oil changes on any oil off the shelf. Oil is different now as SN than it was in the days when a 3000 mile oil change (along with heavier grades) was Bible.
Have you tried different oils? (weights, sun/dino, etc) Does the interval length stay the same?
Originally Posted By: GearheadTool
5000 is the new 3000.
The answer to your question is yes thats fine.
I try to change my old man mine, stop changing oil every 3 months or 3k miles, I just change his oil for him with QS defy and told him dont change until 6 months.
Originally Posted By: Need4racin
I bought all the 97 cent valv durablend oil at the richardson/garland sears. Har har har. 18 single qts of it.
I just recently move here, and doing alot highway driving, not like city in town driving 5-10 miles a day like in jackson ms, im doing 50-60 miles highway in dallas now. So my oil change it a bit different now, still using QS defy,and plan on using it for 5k run.
Great post!
Even I go to 4k+.
The new OCMs can have dino OK at 10k, in some instances. I would balk at this and never go that long on dino, but it shows things have changed.
I'm all for extended oil changes -- I just wonder if the public at large is actually disciplined enough to check their oil level on a regular basis, when they go a year between changes.
Good question, kb. Somehow I think the answer is probably "nope".
Do you think this is acceptable on older vehicles as well? I agree that newer cars should easily go at least 5k OCI though. Maybe even in severe driving conditions.
Not my question, but are you talking about your 95 ? if your engine clean, no smoke. leak.. I dont see why cant go 5k or 6 months on quality oil. and I just gonna stick with what you been doing with it for all these years, dont change the thing
My '98 Grand Marquis was just changed after 1yr & over 9500 miles... It required 1qt added at 5000Kmi and was close to a quart low at the change, now on round two of same with M1...
I'm sticking with what works too. 12kmile OCI's. Sometimes 14k.
258k and counting, it might burnt a liter between changes. I check every 2-3 weeks, and often just change when it's a liter low. Factory called for 10k OCI's, BTW; and the Camry does too now. Synthetic, of course, for both.
FWIW, I recall reading some of the TDi's in Europe were 2 year / 30kmile OCI's, if they had an oil life monitor. I think that is true on a number of vehicles over there, actually.
