Snowblower start up
ROCHESTER, NY
After a snowblower,(any snowblower), has been sitting since last winter, is it wise to pull the cord/recoil several times,(to help lubricate) before actually starting the engine with the electric starter? In my case, I have an 8 year old MTD with a 10 HP Tecumseh.
I once had a 1979 Toro with a 5 HP B&S that I used to do this and I really don't know if this does anything. I used to change the oil seasonally and the engine really blew alot of smoke after about 10 years and then finally lost power due to low compression.
I was just wondering if pulling the cord about 10 times prior to electric starting is the best thing?
I don't know if it makes a difference or not since it's a splash type lube system. I just use the electric starter and slow idle the engine a few minutes before throwing the throttle to the stops.
Great news! I know that it's a splash/sling type lube system. I just thought that I was helping to lube internal parts a bit(prior to full starting), by pulling on the cord with out priming or putting on the choke lever.
Thanks
CB
The engine will turn over much easier and faster with the recoil starter.
Been there done that.; don't know if you can spin the crank fast enough to throw oil around inside.
I always tip the machine to let the oil flow into the cylinder. Grab the blade and nudge it back and forth a few times. Set it down, pull the cord slowly about 5 times fill with gas and let-er-rip.
Just a life-long habit.
I used to put a teaspoon of Marvel Mystery Oil (MMO) in the sparkplug hole at the end of each season and then pull it over a handful of times before replacing the plug. This, along with an oil change and a little Sta-Bil in the gas, was my end-of-season routine.
Haven't added oil through the spark plug hole in a while. Just never felt it did much ... and I'm concerned about plug fouling by the oil. These things are hard enough to start 6 months later.
These engines will run forever if maintained. Just pull the cord and start it without any worries.
I don't do any of that and my John Deere which was brand new in 1978 is still running strong. I have for the past 6 years been using 2 stroke fuel (40:1 mixture) because I am too lazy to keep two separate fuel containers for my lawn equipment. Belive it or not, the spark plug is original.
I just put 4 hours on it yesterday clearning 4 foot drifts from the recent blizzard we had in Colorado.
Bror,
I have been doing the oil in the spark plug hole for 30 years now and it works quite well. I'm pretty sure I discovered this technique in the Tecumseh side of the Ariens Sno-Thro I bought in'77. Sure wish I bought an 8 HP instead of the 5HP 20" cut though. She always smokes blue for about 8-10 seconds and starts on 1st or 2nd pull every time. I have to believe that its worth the effort as I use it in all small engines. I spin it free (w/o plug)2 times to distribute the oil.
Thanks H2GURU. I might just do that with both our snowblowers this year. I started both earlier this month ... just to get them running ... but so far, they haven't thrown a single flake. Looks like early November around here.
Same weather here with 10 day forecast showing perhaps 50s next week! When I store machines for season end I also completely run engine out of fuel. I realize that many do the STA-BIL in the fuel tank drill and everyone says it works fine, but, as I read on other lines, many do carbeurator rebuilds and leaving a fluid with the properties of gasoline in anything has got to take a toll on the rubber internals ?? I thought about adding a shut-off like newer machines have, but I think I'll stick with the tried and true.
I used to drain the all of the fuel out including the carb and float bowl and leave them dry over the season. But I think that is worst for drying up seals as compared to fuel with STA-BIL beacuse, the STA-BIL is at least oily in it's texture even if it isn't a lubracant. Although I wouldn't leave the system full of only gasoline without STA-BIL.
I used to run my OPE empty prior to storage, Not any more, I stabilize the fuel and top off the tank, have pretty much eliminated having to rebuild the carb every spring. I think every small engine stored inside should have a shut off valve installed.
