Originally Posted by Virtus_Probi
Originally Posted by ZeeOSix
Originally Posted by wemay
I still find bottles and jugs which say d1G2 but still not SN+ too. This IMO is old stock in the midst of the transition because the only thing SN+ affects is LSPI whereas d1G2 does as well plus other parameters. So once an oil meets d1G2, it automatically meets SN+. The converse is not so.
I'm not so sure about the statement in red. Searching on the 'net I find no indication that dexos1 Gen2 automatically means it meets SN+. They are two separate ratings. SN+ is an API rating, while dexos1 Gen2 is GM oil specification.
The SN+ LSPI test is performed in a Ford Ecoboost (2.0l) while d1G2 obviously uses a GM engine (believe also a 2.0l DIT)...on that basis alone, they can't be exactly the same test.
You guys are right. Technology, one does not beget the other. I should have worded my explanation differently. If one is looking for LSPI protection and the bottle only has one of these designations present, you are set. If you're looking for the other benefits d1G2 brings, SN+ won't work.
