Originally Posted by Triple_Se7en
Originally Posted by dave1251
I would not be concerned it is not a issue.
I would be concerned, if I had a D.I. turbo engine and I couldn't find a particular weighted SN Plus oil where I shop.
All the non SN Plus oils found in the neighborhood -or exactly the same weight/viscosity you need, won't blow-up your engine. But vehicle engine manufacturers know what's best for your engine - what will endure time / miles on your odometer. It's pretty rare where they are mistaken, in that regard.
Also, the wording-specs on jugs may be attached to old jugs that need to be used. What's inside that jug may be of new specifications. Personally, I only buy what's specified correctly on the jug. I will shop somewhere else, if need-be, to find an SN Plus oil in the correct weight I need.
If the correct oil is inside a jug at Walmart, but the jug is worded incorrectly, shame-shame on that manufacturer, for letting me walk out the door and shop somewhere else ..... or buy a competitor oil that is worded correctly.
Snagglefoot
Both of those jugs pictured, do not say SN Plus on the front. I've seen that QS jug and a similar jug from another manufacturer at Walmart this week, showing all the credentials for SN Plus on the front of the jug. BUT, on the back only say SN.
You showed us the front. But never showed us the back..... where it says SN Plus.
I only mention this, because I've seen them with - and without the SN Plus wording on the back.
Here you go SN Plus: (plus lots of stars
