Small generators
NY
I am looking for a small generator 1000-2000 watts. Obviously Honda 1000 or 2000 are in the running with very good reps, but I also saw Yamaha 1000 and a Robin/Subaru 1700.
Looking for opinions and comments. The Robin has my interest because of size and price. I also think these engine are pretty good from what I have been reading.
Robin used to be Wisconsin-Robin, and yes they do make good engines. They power alot of construction equipment.
Good question. Early this year, Lowes, Home Depot, and Sears sold every one in town, and some people drove an hour or more to find one after the ice storm wiped out our distribution system. We were lucky, our power was only off and back on a few times. Other were without power a week. Fortunately the weather was mild, and people could let their house set without pipes freezing.
I need at least 5 amps at 240V to run my pump. Haven't see anything less than about 4000 watts with a 240 outlet. I lose power and everything is gone, lights, water, heat, cook stove, and even my phone once my 650 VA UPS dies.
Harbor Freight lists several generators with the Robin engines. I am also thinking of a natural gas conversion. Keep the gasoline carb, and make sure I have full tank of gas in my truck in threatening weather. Of course, we don't get good earth quake forcasts.
Funny thing, ever since, Asphlund? has been in town hacking at trees. Why doesn't the electric company try to guess where the next ice storm will be instead of trimming here where many of the trees over the lines already broke off in the last one?
I've got a coleman "pulse 1850" suitcase style portable that I purchased new on eBay about 5yrs ago for around $250. It's a cheapy, but works well for liqhting, portable heat, power tools, etc. I WOULD NOT use it for 'electronic' type items. The governor will oscillate on it at times. It is fairly quiet & good on gas, but does vibrate pretty bad. It's all you'd expect out of a $250 generator!!
G/luck
Joel
I have Gillette with a 10hp Kohler,I like it alot though it is on the loud side.Funny thing is ever since I bought it we haven't lost power,go figure!!!
quote:
Great investment.
quote:
Great investment.
Yeah it is,I should be collecting a little money from my community as I have stopped all power outages...
Ghost i have a homelite generator with a 7.5 subaru/robin engine. It is rated at 4300 watts. i must say that the robin engine is very well built and smooth running. I have used my generator for many projects and it always starts. I would buy a larger generator than you think you will need if you need to power your home.
Thanks for the replys, but interest is strickly small and portable. 50 lbs max weight which limits it to 1000-2000 watts. I am also thinging inverter style to keep the noise down.
I believe my decision is between the 2000 Honda and the 1700 Robin units.
I like the little Honda gensets the best. They are really the highest overall quality.
The Robin engines are robust and I use them on a few things I have at home with great results. Still Honda does a better job of making the engines quiet.
Chris
I too was caught up in a ice storm and was without power for four days. I had a small Nissen 600 watt portable generator that I bought at a garage sale for $125 that I used to power the all important TV (I have a 12 year old at home) a table lamp and both of the small blower motors on my gas fireplaces. That little guy ran 3 to 4 hours on what ever size tank it had and it couldn't be much more than a quart. At the end of the 4th day the little generator was pulsing up and down in speed and was leaking oil. I have not taken it's side covers off to have a look yet, I hope it is something simple. I now have a EU2000I honda waiting for the next power outage, I haven't run it much but it sure is quiet and at 1/4 load it's gallon tank is suposed to last over 10 hours. So under the same usage it should get the same gas usage and still have three to four times the power if needed. By the way I taked to two dealers about the oil they recomend for the Honda and both said Yamalube 10w30. Now if they could just get the price down to a reasonalble level.
For those of you with baby gennies waiting on a power outage - start them up at least one a month so the jets in the carb jets don't succumb to gummy bear attacks.
I am also mixing Fuel Power in my gas cans so all of my small engines get a good cleaning when they run.
I just recieved a Honda 2000eu and it looks like a great unit.
thanks for the help
