Originally Posted By: Bror Jace
I should add that my very conservative (or is it liberal?) break-in procedure above (2 oil changes in the first 10-12 hours) is for a splash lubricated engine only ... one without a full-flow filter.
If your OPE engine (regardless of the application) has a pressurized lubrication system with a full flow filter, I'd swap out the oil and filter at about HALF the recommended interval.
If the manual says an oil change every 50 hours, I'd perform the first one around 25.
The biggest difference is the filter. A full-flow filter will capture the vast majority of abrasive break-in debris the first time it is passed through the filter.
For those with strong stomachs, you might want to take a gander at this that came out of my Ariens snowblower (B&S motor - splash lubed) after about 1.5 hours of run time:
http://i229.photobucket.com/albums/ee149...zps40854167.jpg
Should of stated my application is with a Kohler V-Twin easy on oil, OP was subjecting the Kohler Command splash lube.
Two Kohler(15+ years) splash lube initial factory was changed at 5 hours. There after 25 hour OC per manual. Oil used Delo400. The older Kohler still runs strong believe it was a 1991 model. The other a 1998 a factory defect still going strong after adjustments but runs much hotter versus the older model, hasn't slowed down. Oil capacity is 0.6 qt of oil. Commercial applications.
Oil used the Delo400, never considered any synthetic oil but did for the Kohler V-Twin maybe 200 hours. From my observations the Delo400 on the V-twin after 100 hours trended rather quickly not on a linear scale for the first 100 hours. I believe why Kohler recommends the 100 hour interval. The V-Twin has 850 hours and runs like new a very clean engine.
