Small chop saw recommendation
Colorado
I'm looking for a small chop saw (6-7" blade) for cutting aluminum trim, threaded rod etc. Hopefully something with adequate amprege that it won't come to a halt/bind under light to moderate pressure. I don't have storage room for any more bigger tools even though I know size "usually" means more power for a chop saw. It need not be commercial quality as it will only be for home use and used only occasionally. And decent quality such that it won't burn it self up after it's first use.
in this case as long as the proper blade is being used it does not seem a strenuous or heavy duty usage.
but how much actual room does it save getting a 7" blade vs a 12"
It's surprising. I looked at the 7" and 14" at Harbor Freight and the size difference is considerable! Their 7" will fit on a upper kitchen cabinet shelf. The 14" is more of a counter top tool taking up space I don't have. I was not very impressed with the HF 7" one, it was pretty flimsy but it was close-out priced so it might be worth a try.
Suggest 10" for availability of blades...lots of good options, common with table saws, etc.
For aluminum extrusion I suggest a TCG ground carbide tipped..laminate or specialty nonferrous/aluminum blade.
I "obtained" a Makita 14" chop saw. I purchased it with petty cash ($150 from HF) for a project at work. When we implemented 5S, I asked my manager what he wanted me to do with the saw. He replied, "What saw?" (wink, wink, nudge, nudge...).
It comes in handy for home projects, but it's so big, I have to use it on the floor, on my knees.
