Have a 2009 Silverado with the 5.3 with AFM. Has become a major oil consumer over the last 20k. It has finally become bad enough that the dealer is going to fix it. Currently consuming 1 quart every 1000~1250 miles. They are going to install an AFM oil valve deflector in the oil pan and a revised valve cover with redesigned PCV. This is supposed to cure the problem unless the rings are so crudded up that they have to go back in again and replace the pistons & rings. I'm fine with the new deflector and PCV change but I'd really like to avoid breaking the engine apart if it's at all possible. The engine has had a steady diet of Mobil and QS dino changed in the 3-5k range. Currently has 57k. What are my options for freeing the rings and cleanup, and then additionally should I move to a synthetic over longer intervals or keep short clean-up intervals on conventional? I remember a product called AutoRX used to be pretty popular around here a few years back? Still around or is there something better?
