I heard that you should slowly raise the voltage on a vintage stereo if you have not connected it to 120v in a long time. Something about damaging the capacitors. Anyone familiar with this?
Yup. Very slowly. Use a dual metered variac where you can monitor voltage and current. Look for a current spike and immediately reduce voltage before advancing. Also install a fuse about 1/2 the value of the rated original.
Why? A blanket statement like that will get you in deep doodoo real quick.Capacitors should be replaced before powering it up.
I would check them before replacing them, depending on age I’d likely replace any electrolytic capacitors regardless though.Capacitors should be replaced before powering it up.
It's nonsense. Been in the electronics field for over 35 years and never heard of that. Power supplies on vintage equipment are simple. A dried out open capacitor from old age will cause more ripple riding on the DC which often can be heard as a hum. I have many vintage stereo amps/ receivers and never did what you mentioned. Only way you can quickly damage capacitors is exceeding their rated maximum operating voltage.I heard that you should slowly raise the voltage on a vintage stereo if you have not connected it to 120v in a long time. Something about damaging the capacitors. Anyone familiar with this?
If they are bad.Capacitors should be replaced before powering it up.
We must live in different universes! Seen this many times in tube guitar amps and old ham equipment. SOP to replace theseIt's nonsense. Been in the electronics field for over 35 years and never heard of that. Power supplies on vintage equipment are simple. A dried out open capacitor from old age will cause more ripple riding on the DC which often can be heard as a hum. I have many vintage stereo amps/ receivers and never did what you mentioned. Only way you can quickly damage capacitors is exceeding their rated maximum operating voltage.
Great receiver! In my experience with mine, it wasn’t the caps, but the transistors, their leads corrode over time. Replaced them, and all is good. That old analog stuff sounds greatI have a vintage 35 watt per channel, Pioneer receiver that has one dead channel. It always sounded really good and it is physically in excellent shape. I'd like to get it going again.
Not denying caps dry up and open with age. To take precautions in powering up, no. What damage is going to take place especially with tubes? The caps were bad before even powering up after a long downtime. More than likely you will hear a lot of hum from the ripple riding on the DC out of a power supply.We must live in different universes! Seen this many times in tube guitar amps and old ham equipment. SOP to replace these
35 years ago I had already been working in the electronics field for 15 years, and I've heard of it, and done it.It's nonsense. Been in the electronics field for over 35 years and never heard of that.
Same here, have a vintage Sansui receiver that hasn't been used in the last 40 yrs, the balance potentiometer was starting to go, looking for a repair shop that specializes in vintage audio.I have a vintage 35 watt per channel, Pioneer receiver that has one dead channel. It always sounded really good and it is physically in excellent shape. I'd like to get it going again.
even more so with tube electronics.I heard that you should slowly raise the voltage on a vintage stereo if you have not connected it to 120v in a long time. Something about damaging the capacitors. Anyone familiar with this?
Electrical engineer here, and I've been restoring vintage tube electronics for decades, ranging from antique tube radios to guitar amplifiers, and amateur radio gear. Electrolytic capacitors do degrade if they are discharged for a long time, and they don't always fail open. They can look like a short circuit if the aluminum oxide dielectric degrades, and there is a very real danger of damaging rectifier tubes or burning out transformer secondaries, this does happen. I don't subscribe to the notion that all electrolytics must be replaced without question, but I would never just plug in some tube gear and turn it on.Not denying caps dry up and open with age. To take precautions in powering up, no. What damage is going to take place especially with tubes? The caps were bad before even powering up after a long downtime. More than likely you will hear a lot of hum from the ripple riding on the DC out of a power supply.
