MY 1995 Blazer is ticking me off a little lately.
The transmission seems to be really slow transferring into reverse lately when going from drive directly into reverse.
Seems to take a couple seconds before it actually will switch over.
If you rev the engine a bit it will switch over faster but a little harsh which is something I really don't want to happen seeing the hard clunk into reverse can't be doing anything good for the unit.
The driveline is tight and the fluid was changed 6 months ago but the only thing I didn't change was the filter. The filter was changed 3 years ago and there is only 20,000-30,000kms on it.
Would a clogged filter cause this or could it be the pressure control solenoid in the transmission that is not holding up enough line pressure.
I figure this seeing as soon as a blip the throttle gentley it will switch over faster. But again, I know I shouldn't do that.
Any thoughts guys?
Any thoughts guys?
