D daves66nova Joined Apr 11, 2004 Messages 4,005 Location los angeles May 28, 2009 #1 95 Camry. it seems that there's a slight oil leak right between the engine oil cooler base and the block.How do i fix this this?
Pablo Joined Oct 28, 2002 Messages 60,004 Location Everson WA - Pacific NW USA May 28, 2009 #2 Mating surface unscratched? Flat? Just one filter or every time this happens?
R rshaw125 Joined Aug 18, 2004 Messages 3,392 Location Raleigh ,NC May 28, 2009 #3 Did you get some oil in the groove of the filter? The sealing ring should handle any imperfections. I would take it off and have a good look at it.
Donald Joined Mar 21, 2004 Messages 29,644 Location Near the beach in Delaware May 28, 2009 #4 You need to re-read his forum entry. Its leaking between the oil cooler base and the block, not between the oil filter and the oil cooler base. I would guess there is an o-ring that is leaking.
Boomer Joined Sep 19, 2008 Messages 2,983 Location Pennsylvania May 28, 2009 #5 Agree with Donald. Chevy 4 wheel drive trucks did this as well over time. New O-ring was just the ticket to stop the seepage.
D daves66nova Thread starter Joined Apr 11, 2004 Messages 4,005 Location los angeles May 28, 2009 #6 So how do i take this off the block? that adaptor is fixed to the block.
M mechtech2 Joined Sep 5, 2006 Messages 19,478 Location Chicago Area May 28, 2009 #7 The question is HOW is it fixed to the block. If it is not cast with it, there should be a removal method. Maybe in the center, with the filter off? BTW, if if IS a casting leak, Clean the area very clean and dry, and use JB weld quick built up around it. Last edited: May 28, 2009
