SL vs SM
Bad Axe, MI
 Originally Posted By: FastSUV
 Originally Posted By: Johnny
Less phos and zinc.
SL provides beter protection right Johnny?
Im some applications(flat tappet/higher wearing engines) YES.
ontario canada
so if I had a choice, for the same price, and a normal engine, should I buy the SL or the SM (this is a real choice, because my WalMart carries 21 quart pails of SL 5w20)
Retired | Wausau, WI
Not for my application.
May I inquire, what application is that for?
Two Honda Elements and one Mercury Grand Marquis.
PA
Indeed. Just to stress, though: Those are the only cases in which you want SL over SM. Otherwise, SM is great.
Kuwait
Assuming a vehicle isn't equipped with a strict emission control system (i.e. no catalytic converter, etc.), would an API SL oil be a better choice? And although off topic, what's the difference between SL and SJ? I find it confusing that the newer oils have lower amounts of anti-wear additives than their predecessors - which I suppose is mainly for CAFE purposes? How do they make up for the reduced amounts of these additives, increase friction modifiers?
Bad Axe, MI
IF your car truck has none of that OR your not worried because your car doesn't use oil yea one can use it,SL has higher amounts of Zinc,calcium,phos so in theory it will provide better wear control. But newer cars of today have roller valve trains so a SL isn't as needed so bad.
The difference in SL and SM is for emissions, not cafe. They use other additives to make up for the phos and zinc, like boron and magnesium. Most of the older SJ rated oils were made with Group I base stocks and I would not want to back to that.
Canton, GA
Mercury Grand Marqui.Hey Johnny,you drive a cop car!!! Eh,hahahaha.That Rules!! \:\!
