SILKOLENE PRO S 10W50
Athens, Greece
Hi! Could you please comment about this oil? I use it in a Toyota MR Spyder with a (swapped) N/A 2ZZ motor. The main use of the car is for track days and in ambient temperatures between 30 - 40 degrees Celsius.
I change the oil and filter every 5000 kms and I have zero oil loss. Should I keep using this oil , or could I use the PRO S 10w30 for the winter months at least?
Any other oil recommended for this application?
This oil is now called sold under the Fuchs name in the UK.
A very good oil, highly recommended in the [censored] car scene in the UK, especially the Skyline fraternity.
S stands for Sport And there is a 15w50 version branded R, which is for Race and for cars used more aggressively.
Greece is still fairly warm in the winter months, isn't it?
I would run it all year round without any issues.
You may find the North American bias of the forum will lead to some saying it is too thick and will ruin your engine and call for instant change to 5w20 with some MMO and Kreen.
Check out www.opieoils.co.uk for info on oils, one of the staff there posts up on many forums under the name "oilman" and he is happy to give out recommendations, I have noted he has given out recommendations he doesn't stock when needed so I think he is unbiased.
You can Email Opieoils for a specific recomendation when your car is modified like yours, I assume you drive it fairly hard?
If you are concerned about running 10w50 in colder weather then you could always consider the 5w40 Pro S which is specced for the Lotus Elise with the 1.8 version of that engine.
Not sure if it is the same engine as in yours but I think it is similar, I am sure that engine was a development of a collaboration between Yamaha/Lotus/Toyota but I may be wrong on that. I seem to remember the version fitted to the Lotus Elise had a different oil pump.
Why does the censor think "[censored]" is a naughty word, it is only a Japanese shortened. And in no way derogatory when referring to the car scene in Europe that favours Japanese cars.
Originally Posted By: supercity
It is derogatory or racist dependng on where you are in the world.
I'd direct him to Fawlty and the Major on Youtube from the classic Germans episode, but I'd get banned in an instant. He can find it himself.
