That likely will help temporarily before the silicone makes the noise worse. I wouldn't spray it. Live with it or replace the belt.Hey Yall
I have a chirp on a fairly new Dayco belt - just out of 12 month warranty. Only has 15k kms on the belt.
Only chirps when cold.
If I spray some silicone to quiet the belt will the silicone damage the epdm rubber?
Thanks
Hey Yall
Thanks
Maybe try another belt? Watch your tensioner with engine running to make sure it is working correct (Youtube). I use a Dayco belt on my workplace generator with success (OEM brand). However, for some unknown reason, Dayco does not get much support here at BITOG. So many of the pros here lament the poor quality of aftermarket parts that I spent a few extra dollars and installed OEM parts on my recent belt work. The MOPAR belt is made in Thailand, sigh.Here is the kicker.
All components and belt are new.
Replaced last summer
Thanks.Maybe try another belt? Watch your tensioner with engine running to make sure it is working correct (Youtube). I use a Dayco belt on my workplace generator with success (OEM brand). However, for some unknown reason, Dayco does not get much support here at BITOG. So many of the pros here lament the poor quality of aftermarket parts that I spent a few extra dollars and installed OEM parts on my recent belt work. The MOPAR belt is made in Thailand, sigh.
Last summer? That is not new.Here is the kicker.
15000 kms is quite newLast summer? That is not new.
Gatorback is now Continental. Same belt, different name.Thanks.
I have been watching the tensioner for the last few days - No jumping or jittering - - - everything is running smooth.
Its stumping me - - - I have read the chirps are usually from misaligned belt systems.
I don't have a laser but it all looks and tracks straight to me.
I will probably try a continental belt this time.
In the past I used nothing but gatorback belts - - - - those are extinct unfortunately.
I know.less than 20,000 miles and you shouldn't have a problem with new parts. i like dayco belts, and use their timing belts
They got rid of the belt profile and design.Gatorback is now Continental. Same belt, different name.
Which car is this for?They got rid of the belt profile and design.
They used to sell the conti version but not anymore.
15 honda odysseyWhich car is this for?
