Originally Posted By: Pablo
A lot of what you say is true, but silicone is used as an industrial lubricant:
http://www.dowcorning.com/content/discover/discoverchem/si-lubricants.aspx
http://www.mclube.com/products/91
Zero solubility? You might even be surprised how well a good silicone spray cleans out a firing pin mechanism in a semi-auto slide. When I take my slides apart, they are always spotless inside, no evidence of wear or any gooey organic lube build-up. It cleans and leaves a nearly invisible lube film, so each time it cleans easily. Can't hardly say that for most organic lubes, typically a separate cleaner is necessary. Brake fluid in my guns? Heck no!!!
Bottom line, it does work great in many firearm applications. I've "discovered" something that really works for me.
If it's working for you stick with it. A firing pin isn't going to care what you lube it with. I've never heard of one wearing out from movement (1911)
. Sear surfaces would be another matter.
I assume you are using the Amsoil spray silicone? It's great stuff for what it is. I use it for working on hoses and the like. But if you look at the MSDS:
http://www.amsoil.com/msds/als.pdf
You'll see a significant amount of organic solvent in it. That would explain the cleaning you are seeing. Once this flashes off, the cleaning power is gone.
Thanks for the links. One is just a mold release, not mechanical lube, and the other states:
Quote:
However, the surface tension of silicone fluids is very low, and they tend to spread more than organics.
Their high spreading and high compressibility limit the internal pressures (viscosity increases) that can build within silicone materials when they are used as lubricants. This limits their load-carrying capacity compared to organic lubricants with the same initial viscosity. However, silicone lubricants do have sufficient load-carrying capacity for all metal-to-plastic and plastic-to-plastic lubrication applications.
Which is exactly why I don't use it.
Machines that use silicone lube are specifically designed for it. I would assume they use larger bearing surfaces to accommodate the reduced load carrying ability of silicone.
