Quick background -
'98 Sienna. Running M1 ATF for many years now. Couple months ago put in 3 qts Schaeffers Synth ATF (which I know is relatively thin).
Everything was fine (except the trans has a slight buzz noise often just before shifting - doing this for the past year).
Last wkend had a new starter put in (at dealership). Got the van back, and now it "jumps" when shifting. That is, when it shifts (eg) from 2nd to 3rd - it feels like I've been bumped from behind. VERY noticible/obvious. This started immediately after having the starter put in.
Took it to the dealership this a.m. - they looked at it and said "we didn't do it" - said it was possible engine mounts or ? I would think engine mounts would go slowly, not in one day after the van is worked on (?)
Any ideas?
I'm wondering if the thinner ATF along with the computer making adjustment for whatever they did with starter - perhaps the computer is a bit lost. I'm thinking about putting dino ATF back in (several change & fills at one time). (?)
Any ideas?
