I replaced the inner axle boot on my 2008 Sienna today. These axles use a tripod rather than a CV joint on the inner section of the axle. The splined ID of the tripod had a slight chamber/bevel on the splines on one end that I assumed was to make the insertion of it onto the shaft easier. In looking in the manual for torque specs I saw a diagram showing that the bevel should have been facing the other direction. I assume that this was to have the bevel next to the retaining ring on the shaft so that if it were forced against the ring the bevel would force the ring down into the groove rather than have the ring pop out of the groove. The thing is, I don't recall the bevel being large enough to go over the OD of the retaining ring to actually do this.
Does anyone know why the bevel orientation on the tripod would be important?
