Originally Posted By: dnewton3
Originally Posted By: paulri
Thanks for posting the link to this. I'll read it later. I did find a version of it that doesn't require a scribd user account:
http://www.plaisance-pratique.com/IMG/pdf/SBN_Oil_3810340__5jun13.pdf
Originally Posted By: userfriendly
https://www.scribd.com/document/193910963/Cummins-Engine-Oil-and-Analysis-Recommendations
The last few paragraphs is of interest to me or anyone who uses wear metals in UOAs to determine engine wear.
I'm not going down the extended oil drain slippery-slope to save a few bucks on oil and ruin an engine in the process.
I would say 20 years of data collecting down the 'ol drain, Lol.
Read the last sentence of that entire paper, please; I'll quote:
It means that oil analysis becomes meaningless after the engine oil is excessively contaminated."
AFTER oil becomes overtly usurped by contamination, then all bets are off. And I agree with that; never claimed anything different. But most of our BITOG UOAs, and certainly those that I screen in my set of 15k+ UOAs in the database, are not "excessively contaminated". High amounts of soot/ox, or high fuel dilution, or extremely elevated metals, or heavily diluted via replenishment can all affect the validity of UOAs. I could not agree more. BUT .... if those things are NOT present, then the UOA techniques are valid.
That paper (written 10 years ago, and updated occasionally), never said that UOAs are worthless at all stages, nor does it put forth any sort of "proof" for it's claims. There's not one shred of data in that paper. There's no SAE study (or internal Cummins study) they show relevant information for. There's no charts of UOA data and then corresponding tear-down measurements. There's no electron-bombardment data. Etc .... It's just words with no information to prove it's validity. I am not at disagreement with the pretext; UOAs that are heavily contaminated and/or diluted should be under heavy scrutiy for accuracy. But UOAs which are unaffected by those concerns are completely valid. And that paper from Cummins never says to avoid ALL UOAs; it just states reasons why UOAs would be subject for scrutiny and subsequent dismissal
IF they are compromised by conditions of the oil.
They also have this to say about UOAs:
"Sample results determined by the same laboratory using the same technique can be safely compared." (using the same lab and methodology is valid)
"Abnormal wear causes abnormal accumulation of wear metals in the used oil." (stuff that is not typical will cause atypical results)
"Abnormal wear, which can indicate a problem, usually only involves elevated levels of one or two metals." (atypical results may be narrow in scope)
I will point out that nowhere in their paper that I can find do they address the topic of "normal wear". Abnormal wear? Yes - it's discussed. But Normal wear? Nope - they don't touch that topic at all.
Now look at the title of my article:
https://bobistheoilguy.com/used-oil-analysis-how-to-decide-what-is-normal/
I discuss "normal" wear. I use statistical analysis in both mirco and macro data collections to determine what is typical of daily use.
I will also point out it's a bit of a dichotomy that some of you will need to resolve in your heads regarding the fact that you would believe this paper from Cummins would indicate that UOAs are worthless, but Cummins (and many OEMs and other trustworthy sources) are cited here as having ppm limits on wear metals ...
http://www.calrecycle.ca.gov/Publications/Documents/UsedOil%5C2008020.pdf
(page 11 of the report)
Ironic, if not hypocritical, that Cummins wants to say UOAs are not trustworthy, but then establishes ppm limits on metals that would only be discoverered via UOAs ....
So, in short, even Cummins says it's OK to use UOAs, as long as the lab/methodology is consistent and the oil is not grossly contaminated. They also set condemnation limits for UOA wear metals.
Once again, those of you whom want to take things out of context, and/or morph information to fit your narrow viewpoint, need to take a broader approach to understanding this entire topic(s).
Just sayin'.
I don't know why anyone would use data from Cummins for anything.They make poorly designed, archaic engines. To put it in more technical terms, their engines are pieces of [censored].
