My car is 02 Civic LX A/T with 40k on it. Manual says i should change spurk plugs at 120 000 miles. So my question is: Should I still pull them out to check them to see their condition or just leave them alone? Thank You.
Quote:
The downside to checking plugs early is the wires get cooked so the more times you have to touch them, the more likely they'll fail or break.
Quote:
BTW in most new Honda cars you can pretty much forget about ignition system problems. Wires, distributors, etc have been eliminated so all thats left is a coil and a plug. Coils do fail on rare occasions but I have never seen an NGK Honda OEM plug fail. And yes, most of the plugs will last over 100K without a problem.
If you want to keep your Honda running well, focus on factory recommended fluid changes. Other than that, there just isn't a whole lot of maintenance items on the newer cars.
Quote:
Fuel filter is in-tank and it would cost you quite a bit to service/replace. Check with your dealer RE: fuel filter replacement intervals.
