Patman
Staff member
I've been thinking about this a lot today and it really bothers me. Are all oil companies like this, or do you think it might have just been at that one refinery? I find it hard to accept that they can't make their batches of oil more uniform. It also makes it harder to determine if your oil has thinned or thickened through analysis, because you might not know exactly where it started at! I also wonder if the other factors of an oil vary this wildly? In other words, if they claim the oil has a pour point of -40F could it vary as much as ten degrees either way? If so, an oil that might be marginally safe to run in your winter climate might just end up with one batch being safe and the other being a bit risky. Not good!quote:
Originally posted by JonS:
Patman,
The vis of 9.8 vs. 11.5 is at 212 degrees. I used to watch this also and figured, my oil is not going tobe at 212 all the time. It might be at 180 one day then 250 the next , depending on how you drive ect. Plus, this is just an average from a sample taken. One guy at a refinery i talked to went thru some of a batch he was testing. Some was at 10.2, some was at 11.7. These numbers on the spec sheets are averages and change (i've heard) dramatically with a few degrees either way. So, your Max- Life at 250 might be "thinner" than Mobil1 at 250 because of the viscosity index is higher.
What would make an oil vary so much in viscosity from one being at 10.2 and one at 11.7? Would they add different amounts of VII? Or is it the base oil which determines this variance? And if so, wouldn't a synthetic be subject to less production tolerance since they are "custom making" the base oil? (I'm talking real synthetics here, not the group 3 pretenders)
