- Messages
- 179
- Location
- Forest Hill MD
I'm using Amsoil 5W-20 and it contains virtually no Moly:
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=11;t=000074
Should I add some?
quote:Does switching the XL series over to a group 3 base oil make it better though? I think not.
Originally posted by Dick in Falls Church: Having dealt with the folks at AMSOIL for over 25 years, I suspect that they would use moly if they though it would make their oil any better---
quote:True, it doesn't. I think what Terry says is very true for a lot of there oils. While it is a well built oil, they don't hold up like they use to. I never really thought Amsoil had bad wear numbers. In fact, I think they are generally a bit better then M1. My biggest complaint with there oil is the TBN depletion and out of grade viscosity. Moly wouldn't help this, as far as I know. It seems Boron and Moly though are the way to go these days. [ May 21, 2003, 08:19 PM: Message edited by: buster ]
quote:Slould be interesting Spector. I'm also thinking of adding it to the Delvac 1 for my son's Piston-Slapping 3.4 GrandAm
Originally posted by Spector: I will let you know. I have added the Schaeffer #132 to two vehicles and I use the Amosil 10W30.
quote:True, but nobody knows for sure if they'll get even better with the addition of moly, so someone might as well give it a try!
Originally posted by TooSlick: You'll get excellent wear numbers without the moly ... TS
