Planning on installing a shooting range in my basement. It will use two basement walls and I will build a block wall to enclose the entire lane. The I.D dimensions will be 28' x'6 ' and added wall will be 6' 5" high. I will soundproof the walls and add rubber flooring to further absorb sound. There will be a hepa filter drawing air from the shooter to the target.(filter will be on outlet).
The shooting distance will be seven yards. I have a piece of mild steel 24" square,and 5/8" thick. It will be mounted downward at 45 degrees. The bullets will deflect downward into a 4' x 4' sand pit. Have a few details to work out.
Anyone do something like this or have some thoughts?
