SHELL ROTELLA T6 UOA IN HONDA SHADOW AERO 750
Marietta, GA
I have been using the T6 in my motorcycle for several years and decided to send in a sample at the last oil change. It's an '07 with 44,000 miles on it. I ran the T6 for 4,070 miles with no oil added. Here are the results.... Aluminum 6 chromium 3 iron 15 copper 27 lead 0 tin 0 moly 67 nickel 1 manganese 0 silver 0 titanium 0 potassium 0 boron 33 silicon 16 K & N air filter sodium 6 calcium 750 magnesium 1,228 phosphorus 1,096 zinc 1,294 barium 0 SUS viscosity @ 210* F 59.4 cST viscosity @ 110* C 10.06 flashpoint 380* F fuel <0.5 antifreeze 0.0 water 0.0 insoluble 0.3 Blackstone said that the high copper reading was nothing to worry about at this time. Any comments?? Thanks.
MA, Mittelfranken.de
I don't know how you would figure out exactly where the wear metals are coming from anyway in a shared gearbox/clutch/engine combination.
Midwest
I wouldn't run it so long next time. That's a very LOW 30 grade now. Or is the bike okay with a 30? I'm thinking of my V star 650 (also shared sump) which is spec'd for a 50 grade for summer and a 40 for the cold weather. Of course mine is air cooled.
America's Dairyland
Honda would assume that any oil you put in there will shear because of the transmission. Their own oils shear and my VFR has an 8,000 mile change interval. They're only the largest engine manufacturer in the world. Mods--this should be in the motorcycle subforum.
TOMJ
Marietta, GA
The owner's manual does state that a 10w-30 oil can be used. Also, the engine is liquid cooled.
