MAKE/MODEL:Saturn 1.9L 4-Cyl
FUEL TYPE:Gasoline (Unleaded)
ADDITIONAL INFO: 2001 SC1
OIL TYPE & GRADE: Rotella 5-40 / Castrol Syntec 0w30
MI/HR on Oil: 6400 / 6,500 Miles
MI/HR on Unit: 167,900 / 161,500
Report Date: 5/7/2010
Make Up Oil Added: 1qt 10-30PP @3000 / 2qts
ALUMINUM 3/4
CHROMIUM 1/1
IRON 15/18
COPPER 2/1
LEAD 0/0
TIN 1/0
MOLYBDENUM 62/10
NICKEL 1/1
MANGANESE 0/0
SILVER 0/0
TITANIUM 0/0
POTASSIUM 1/4
BORON 22/7
SILICON 54/18
SODIUM 9/14
CALCIUM 1368/2190
MAGNESIUM 1018/577
PHOSPHORUS 1027/990
ZINC 1192/1290
BARIUM 0/0
PROPERTIES
SUS Viscosity @ 210°F 74.6/67.3
cSt Viscosity @ 100°C 14.15/12.23
Flashpoint in °F 440/405
Fuel % Antifreeze % 0.0/0.0
Water % 0.0/0.0
Insolubles % 0.4/0.3
TBN NA/5.8
TAN
ISO Code
The mild increase in silicon was the only unusual finding here. It could show some dirt getting past
the air filter, so we suggest having a look at this. It could also be harmless sealants used when replacing the
cam gasket. Wear still looks good, so we doubt any serious bearing or piston slap problems are present.
The oil was normal in viscosity and free of any fuel dilution or anti-freeze. Insolubles were low at 0.4%
showing good oil filtration. Other than the silicon, this engine appears perfectly normal here at 167,900 total
miles. Another good report.
I replaced the cam cover gasket at 3k miles into the run, started leaking pretty bad, appears to have sealed up now, consumption is almost non existent now. Top off oil was 1 qt 10-30 PP, at the same time as gasket replacement. Oil level was about 3/4 up on hash marks when changed. I have now jumped on the Ultra bandwagon to keep it "factory clean". I changed the oil because I had the time and it was about the same interval as last time to compare the 2. I may run this Ultra quite a bit longer.
ALUMINUM 3/4
CHROMIUM 1/1
IRON 15/18
COPPER 2/1
LEAD 0/0
TIN 1/0
MOLYBDENUM 62/10
NICKEL 1/1
MANGANESE 0/0
SILVER 0/0
TITANIUM 0/0
POTASSIUM 1/4
BORON 22/7
SILICON 54/18
SODIUM 9/14
CALCIUM 1368/2190
MAGNESIUM 1018/577
PHOSPHORUS 1027/990
ZINC 1192/1290
BARIUM 0/0
PROPERTIES
Water % 0.0/0.0
TBN NA/5.8
TAN
ISO Code
