shelf life for liquid tape
I believe its lacquer based,and it dries up rather quickly after opening the can.I have had a can go solid on me after one use.
So maybe the small tubes that StarBrite sells would be better. A can is a lifetime supply for many.
How would a butt connector sealed with liquid tape compare to a adhesive lined heatshrink butt connector, in a trailer where it will get water and road dirt/salt on it.
Here's a little trick if you have a MIG welder... before closing the can, shoot a little Argon into the container. It will displace the air and, because it's inert, the paint, glue, liquid tape, etc. won't dry.
