I first began browsing this thread because I am currently using 2/3 of a pint of #132 mixed in with my Schaeffer Supreme 7000 5W30. Why? Because I was concerned with wear in my Civic's engine, mostly as a result of coolant contamination, and I was fearful that the 5W30 (which is what I had on hand when I last changed my oil) wasn't thick enough and/or would not provide enough protection for 4,000+ miles until my next oil change in the spring.
When I first picked up a bottle of this stuff, I figured it was probably like STP: a polmer goo with a heavy dose of barrier additive. But, while STP uses ZDDP, the Schaeffer #132 probably used molybdenum (as the name implies). I have since been set straight by the
'Kule Dewd that it's much better than mere goo with a different 'flavoring.'
But so much has been said here, I felt the need to comment on bits and pieces from above:
Bob: (Re #132 and the term "snake oil")
"It's an additive designed for a specific intended purpose and that intended purpose is not a snake oil."
But what if I rubbed it all over my pet python "Reggie" to give his skin a nice, glossy shimmer? Could I call it 'snake oil' then?
Yes
Dragboat, I think that oil analysis of yours after using some #132 is the single best one I've ever seen.
'Boat:
"If you want ... moly & antimony in a formulated, proven oil, Schaeffer has it already mixed for you in 32 ounce bottles."
Um, bottles of #132? You mean 16 ounces (1 pint), right? Either that or I can't read labels ...
... and my hands have suddenly doubled in size!
Does anyone know if gigantism is a possible side effect of antimony contamination?
Patman:
"I DO need a new keyboard! I can no longer see the letters E,S,D,C,N,I or L, and K and M are disappearing fast too! I'm not just posting a lot in this forum though, on one of the boards where I'm a moderator, I have over 21,000 posts, and on another one I'm at 3,300, and yet another at 2,000."
OK
Patman, with that disclosure, you need to tell us your secret. What kind of barrier lube do you use on your fingertips? Is "Liquid Glove" all it's cracked up to be or just another reptile lube? Do you have any analysis you can share with the rest of the group? C'mon now, don't be shy ...
TooSlick:
" ... you don't see me suggesting folks play with red fuming nitric acid or hydrazine in their garage."
No, of course not. You selfish buggers are hoggin' all the fun for yourselves!
'Kule:
" ... all you great people who come to the forum with wit and humor and take it "all in stride." While so much of this stuff is technical and serious, you guys make it cook with your neat and fun attitudes, wit, and humor (weird sometimes, but I like it!). "
I have no idea what you're talkin' about.
Bror Jace
