I was thinking of running Motul 300V 5W-40 in my car. This oil is top-of-the-line Ester racing/street oil.
Here are the specs
This is an SG rated oil. What does that mean exactly? Thanks.
quote:Yes, but I consider European oils to be of higher quality than North American oils, and Redline is much more expensive here in Canada (C$17/L)
Originally posted by sbc350gearhead: Isn't redline ester based?
quote:Can you give me some evidence of this? Im skeptical of it. 300V is Motuls best... Also the reason its SG rated is purely because of the high zinc/phosphorous levels. Same reasons as Redline really... 300V was built for engines that are stressed hard as a first priority, not manufacturers approval.
Originally posted by vvk: What you must realize is that 300V is for racing use only. It is not for street driven cars. I have seen reports of people having major problems with this oil.
quote:I am sceptical about RedLine in street driven vehicles just as much. I know what you are saying about ZDDP levels, though. I can direct you to www.auto.ru/wwwboards/oil. You will probably be able to use the search function (top of page, type in field with long button on the right) to search for Motul or 300V. If you don't read Russian, use an on-line translator after you get results
Originally posted by Leo:quote:Can you give me some evidence of this? Im skeptical of it. 300V is Motuls best... Also the reason its SG rated is purely because of the high zinc/phosphorous levels. Same reasons as Redline really... 300V was built for engines that are stressed hard as a first priority, not manufacturers approval.
