well i have been reading my repair book for my 91 honda accord FI I4 2.2L and i been adjusting my idle with the throttle cable. thats the cable that is connected with the gas pedal. well i read the book and it said that the idle should be adjusted by a screw on the intake manifold. it siad that i must first disconect the IAC and then adjust it. when i disconneted the IAC the idle went very low. i was trying to read my volatage meter on what was the speed of the RPM but it never changed. it stayed at 11.50. the book said to raise it i should turn the screw and when i did i felt the engine;s rpm go higher but the voltage stayed the same. the book said that the voltage would change, im not sure now. so i adjusted it to where i was before and just left it there. anyone had any experiances with adjusting idle??
