1994 Chevrolet C1500 with 5.7L. Has AC w/O AP and I think 100 amp alternator.
Question is how do you know if the tension on the belt is too tight. Belt is a Goodyear Gatorback I put on about 8 months ago. Everything seems fine but I was looking at some alternators (really just checking prices......just in case....)for this truck and there is a common warning about excessive belt tension damaging the alternators so I went out and checked mine. When I put it on I did not think anything of it but from just pushing on the belt compared to my other two vehicles the belt does seem to have a good bit more tension.
I then looked at the belts and Goodyear indicates the belt as 95.25 inches (effective length. Dayco specifies the length as 95.50 inches. Would a 1/4 inch make much of a difference with an auto tensioner? Could it be a tensioner problem? (I always thought they got too loose not vice versa but.....) Or am I worrying about nothing since no actual indication of a problem.
