Originally Posted By: Vikas
And rebuilding leach field means you are looking at $40-50K :-(
In 2011, a brand-new system consisting of a 1500gal tank w/ sand filter (as opposed to leach field) cost me $8500 all-in. This replaced a failed 500g steel tank, leach field system from 1955.
All this had to be done for a house I had already sold! The new owner loved me.
Leach fields are non-existent in the W.NY area now. Almost no-one has soil that will allow for it, thus the need for sand filter systems. You can repair a leach field system all you want, but a brand-new, permitted by health dept. system will be a sand filter.
In regards to septic additives? Totally unnecessary. Some additives can push solids into your leach field or sand filter and/or clog your Zaebo filter if so equipped (and you're lucky).
Like said, system pumpings totally depends on the size, condition and amount of load on the system. You can ignore getting it pumped, but eventually, non-digestible solids (that form a floating layer) will build up to the point waste water cannot exit the tank. If you don't have an outflow filter (Zaebo, etc..), solids flow into your absorbtion system and now you've got big problems.
FWIW, current home has a 1000gal concrete tank and leach field system. I let it go ~4yrs (just had it pumped) and the sludge layer was super thick. I'll go every 2-3yrs now until the system fails.
