Quote:
Anyone have a cross-reference list between B&S and auto filters? My father-in-law's tractor needs an oil change soon.
This is a real pet peeve of mine; B&S & Kohler both charge major $$$ for a filter that can be replaced by a garden variety Puro/MC/WIX/Fram for 1/4 the price.
These filters are pretty much standard across the B&S/Kohler lines.
3/4-16 thread; 2.734/2.430/0.223" gasket - there are a bunch around that'll fit that application - you're limited primarily by length.
Puro 10241 = $3.00 +/- at Advance Auto;
SuperTech ST3614 = $3.00 at Wally's.
MC FL400S = $3.50 - 4.00 at Wally's. Almost 5" long, might not fit if you have a length restriction.
WIX 51056/NAPA 1056 (2.7" long) or the 51348/1348 which is 3.5" long (the cross for Kohler's "long" filter #52-050-02) run around $6 or $7, depending on where you find 'em, and offer a 20 micron rating.
And here are a couple other threads on the topic:
#1
this is from a post in that thread:
"Briggs/Kohler type" 3/4" X 16 threads 8-11 PSI Bypass Gasket 2.734"OD X2 .430"ID 0.226" thick
Length" Wix Purolator Hastings Kohler B&S Baldwin MotorCraft AC Walmart JD
2.3" 57035 NA LF503 2805001 492932 B7165 NA NA? NA ?
2.7" 51056 L35310 LF302 1205001 492056 B1410 NA PF2210 NA AM125424
3.4" 51348 L10241 LF157 5205002 491056 BT223 FL793 PF53 ST3614 AM101207
4.8" 51516 L20195 LF134 NA NA B243 FL400A PFL400A ST3600 ?
#2.
