Sealing truck cap windows.
wtd
southwest Mo.
I just bought a used ARE truck cap. The front and both side windows leak water. Has anyone ever taken these type of windows out and resealed them?
I'm not sure what type of seals they use to seal the windows to the camper shell. The shell is fiberglass.
For those that have done this, what type of seal did you use. I really don't want to use a silicone type sealer if possible. Thanks for any suggestions.
Wayne
I wonder if an RV putty could work, but I'd to see the gray slowly turn black.
I think I have the same problem, front window looks like t has a slow leak. Not sure how to pull the windows.
I'm not sure how to pull the windows either but from the inside of the shell, there are a bunch of screws around the window frame that I assume is what holds the windows in. I guess I will just have to mess around with it and figure it out. Thanks.
Wayne
