- Messages
- 2,325
- Location
- Ontario Canada
I have a 5 Gallon Air Pig and I replaced the the valve assembly with an all brass one after the the red plastic tap handle on the original broke.
Problem now though is it leaks at the fitting. I am using teflon tape on the threads. The original fitting had a dark gray cement looking sealant on the threads. It seemed a hard set clay.
Any suggestions?
I fill it to about 110 PSI tops.
