Originally Posted By: racin4ds
Did some research, looks like it is mostly Chevron, also found this exert on JD's site concerning the 0w40 which looks like it could give M1 0w40 a run!
"Plus 50 II Synthetic Engine Oil (0W40)
Synthetic Plus-50 II Premium Engine Oil (SAE 0W-40) has been designed to provide advanced lubricant performance in modern engines to meet the requirements of EPA regulations. SAE 0W-40 Plus-50 II is a full synthetic PAO (Poly Alpha Olefin) based oil to provide excellent performance.
Applications
Excellent for all diesel engines requiring 0W-40 viscosity and API Service Classification CJ-4, SM, and Mack EO-N Premium Plus 03. Superior performance for customers who operate in extremely cold conditions and want to maximize engine life and performance.
Features and Benefits
· Unique to John Deere – formulated with exclusive Plus-50 II additive and 100% PAO (polyalphaolefins) synthetic base oil
· Excellent for other brands of diesel engines
· Excellent for all automotive heavy- and light-duty diesel engines
· Synthetic base stock with the Plus-50 II additives provide excellent performance in a temperature range of -40°F to 122°F (-40°C to 50°C)
· Additive package reduces engine wear and provides superior protection against high-temperature thickening as compared to competitive oils – offers additional protection in neutralizing corrosive acids formed as by-products of combustion
· Formulated specifically to inhibit oxidation, deposit, corrosion, and wear with superior soot control
· Performance is equal to Plus-50 15W-40 in wear reduction and antioxidation tests
· Provides maximum sludge and varnish control
· Superior low-temperature fluidity reduces engine startup wear in cold weather
· Drain intervals may be extended up to 500 hours when used with John Deere oil filters in John Deere engines
· Reduces maintenance costs and downtime, and extends engine life
Cold you provide a link so I can read more about JD's oils?
