Originally Posted By: itguy08
Why should we blindly believe the scientists?
If you don't want to, you shouldn't. Read the papers. Just be prepared for a slog, because scientific literature tends to be pretty thick if you're not used to it.
Science has been wrong many, many times before.
And it will continue to be wrong in the future. No question.
The question for us isn't whether it's right or wrong. The question is whether it's more or less likely to be right than we are, sitting here with our keyboards. The fact that you HAVE a keyboard should make the answer pretty obvious.
These same scientists said 30 or so years ago we were headed for an Ice Age. What changed?
Once, we thought the earth was a sphere. Then we realized that was wrong, and started calling it an oblate spheroid. Now we know that's wrong, too, because there are other slight bulges here and there. Knowing that, are you now prepared to say we can't trust science about the roundness of the earth? Does this make you any more willing to listen to someone who says the earth is flat? Science was wrong, after all!
Climate science has moved on quite a bit in 30 years. Details have come to light. Projections have improved. The fundamental idea -- that human activity is altering the climate, with potentially bad consequences -- has become more obvious, not less.
Not to mention Neil deGrasse Tyson is an Astrophysicist, which has nothing to do with climate science. So we should discount him too since he doesn't actually work in the field?
Absolutely. His point about science generally is the important part here. I happen to know he's also right about climate science, but I agree that you should discount his opinion on it because he's not in a relevant field.
Here's a better place to start -- lots of sources cited, all of them well respected scientific institutions in the relevant fields:
https://climate.nasa.gov/scientific-consensus/
