2008 Ford Crown Victoria Police, 4.6L in police service.
First run on Schaeffer's Supreme 7000 5W-20 (numbers on left)
Vehicle is equipped with an hour meter which only accumulates time while engine is running in park.
6039 mi + 156 hrs of idle time on oil. For reference, Ford considers 1 hr of idle time equivalent to 33 mi of driving=11,187 mi equivalent, total.
Towards the end of the run the alternator pulley loosened up and began to slip on the shaft. The serpentine belt was destroyed by the resulting heat production. The engine over heated and required the replacement of 1.5 gal of coolant to refill.
37,647 mi on vehicle
Napa Gold oil filter
0 make up oil, oil level was just above add mark at time of sampling.
VOA on right
Testing by Polaris Labs
UOA--------------VOA
Fe----26----------1
Cr-----1----------0
Ni-----0----------0
Al-----3----------0
Cu-----1----------1
Pb----10----------1
Si----20---------13
Na----20----------9
K------3----------0
Mo---467--------516
Sb-----8----------7
B-----12---------13
Mg----38--------123
Ca--2294-------2108
P----753--------881
Z----875-------1021
All other in values = 0.
Fuel=<1%
Visc@100C= 8.2----9.4
TBN = 3.41--------7.3
Ox= 15------------9
Nit= 21-----------10
