sample of 15w-40 Blend from the 1.6L 1993 Honda Civic,4cyl. OAI was the lab.
sample date 4/18/02
Total miles 112,656
Oil Miles 4173
Glycol Neg
%water %fuel Vis 100 c 13.2
% solids trace
Oxd 21.1%
Nox 24.3%
TBN 6.6
Fe 21
Cr 1
Pb 4
Cu 6
Sn 1
Al 8
Ni 0
Ag 0
Mn 1
Si 9
B 28
Na 135
Mg 111
Ca 2208
Ba 0
P 1174
Zn 1291
Mo 71
Ti 0
V 0
Cd 0
Used a Ac pf 1127 oil filter, K&N air. Driven hard,both hot and cold temps.
Low wear on a vis that is NOT recommended by Honda.
For example Fe averages 32.5 ppm so 21 is low.
Flow rate good with no problem cold starting,was slower to turn but not problematic. Fuel economy was not affected by the motor oil at all.
sample date 4/18/02
Total miles 112,656
Oil Miles 4173
Glycol Neg
% solids trace
Oxd 21.1%
Nox 24.3%
TBN 6.6
Fe 21
Cr 1
Pb 4
Cu 6
Sn 1
Al 8
Ni 0
Ag 0
Mn 1
Si 9
B 28
Na 135
Mg 111
Ca 2208
Ba 0
P 1174
Zn 1291
Mo 71
Ti 0
V 0
Cd 0
