Schaeffers 15w40 CI-4 +
Capitol City
Hello Everybody, Here is a copy of a UOA for my 1996 Dodge RAM 2500 diesel. My first sample was pulled at 4624 miles with the Schaeffers oil and was unsure of what kind of oil the previous owner was using. I changed the drop in air filter to the Amsoil EAA106 when the lab noted the silicon level being high. This last UOA took me approx one year to go 7000 miles. Is this silicon level something to worry about ? *********Need help with the attachment. I do not see the file manager to upload my UOA. *******
Boczech
Capitol City
Ok then here it goes. Air filter is from Amsoil and was installed approx. 20,000 miles ago. Any comments are appreciated. MI/HR on Oil - 7,000 MI/HR on Unit - 209,136 Make Up Oil Added - 0 qts ALUMINUM - 2 CHROMIUM - 1 IRON - 14 COPPER - 2 LEAD - 7 TIN - 2 MOLYBDENUM - 318 NICKEL - 0 MANGANESE - 0 SILVER - 0 TITANIUM - 0 POTASSIUM - 1 BORON - 10 SILICON - 79 SODIUM - 6 CALCIUM - 3328 MAGNESIUM - 14 PHOSPHORUS - 1178 ZINC - 1372 BARIUM - 0 SUS Viscosity @ 210*F - 71.1 cSt Viscosity @ 100*C - 13.25 Flashpoint in *F - 435 Fuel % - <0.5 Antifreeze - 0.0 Water % - 0.0 Insolubles - 0.4 TBN - 7.4 Blackstone Comments: No real problems showed here. These readings are all still in the normal range so we have no reason to suspect any problems are developing. Silicon was excessive, but we are leaning towards this being from the recent use of silicone sealer or lubricant and in that form, it's harmless. If it was from dirt, then wear would have read higher. The TBN was strong at 7.4 so lots of active additive was left. Try 9,000 miles on the next oil.
salesrep
$100 Site Donor
lllinois
I am going to agree with Blackstone labs. Schaeffers oil 700 15-40 diesel engine appears to have held up very well... Extend your drains if you choose. Let's see what the next sample for sodium says.
Houston, Texas
Lead is sort of high. My engine show like 1 or 2 ppm for lead. But other than that it looks good. Hope my engine has wear numbers like that once it breaks in. I guess 209,000 you can't expect led to be as low as a newer engine.
Boczech
Capitol City
You mean silicon right ?
Bad Axe, MI
That ams air filter isn't working too good? you used a silicone sealer?? held grade,nice report try 10,000 next time,nice add pack love the CI-4 oils
Boczech
Capitol City
I am thinking about trying another Air Filter since I haven't used anything close to a silicon sealer. Thx Bo
Bad Axe, MI
I hope there better then that i have one in my Z71.
Boczech
Capitol City
That's what I thought to so I am looking at the AFE dry filter.
salesrep
$100 Site Donor
lllinois
The AFE is one of several good filters that'll work for you. They'll also improve performance a tad. What size exhaust do you have?
Boczech
Capitol City
It is the stock system right now with plans to upgrade to a 4inch here in the future
dnewton3
Staff member
Indianapolis, IN
Everything looks very reasonable except the aforementioned Si. I'd try a different filter; consider going back to stock to establish a base line, then experiment with other filters if you choose.
