Apologies to all my fellow mechanical engineers at GM ....
I actually gave some thought to this bias in wear rates instead of shooting my mouth off.... There are three main reasons why Fe levels are significantly higher in the 5.7L,GM Vortec engines:
1) They use a fully lubricated timing chain and gears and not a timing belt and cogs that run completely dry. I suspect this GM chain generates lots of the iron wear you see....Do an oil analysis after a timing chain swap and I bet iron levels are through the roof!
2) The valvetrain uses a roller, pushrod and rocker arm between the cam lobes and the valve lifters - these are all ferrous materials that wear....The cam lobes on the DOHC toyo engine push directly down on the valve lifters, ie there are simply less wearing parts with this type of design ....
3) The GM engine has 20% more displacement, which translates into more "swept" cylinder wall area and more iron wear.
Not-So-Slick
Not-So-Slick
