Originally Posted By: Lapham3
Good for you. I like the approach to do the job with your aquirred skills, without big expense and not replacing servicable parts. This was more the mode many decades ago when vehicles/farm equip were often repaired by many owners. I was operating this way and gradually moved into more of a complete 'rebuilding' mode. In more recent times I moved back some after too many brand new, but poor quality parts and a lot of the machints/shops going down hill before finally going away. I'd also like to see your thread on this
Thanks, and I agree, there are many jobs I've done where used OEM parts were better than aftermarket new. The main goal of the last engine was to get it done as cheap as possible, the price of fuel was skyrocketing at the time, and I only had my diesel truck running. Within a few days, I had a 30+ mpg cruiser back up and operational.
A few people questioned me on re-using 140k mile oem piston rings. At the time, the cheapest new ones were $90 for a set. I had seen the engine that these came from running and had driven it, compression was great, so IMO, they were perfect candidates for re-use. I checked the gaps before install, and only one oil control ring was on the high side of the spec range, the rest were well within the green area of their limits. After the 100 mile oil change on the 'new' motor, a compression test showed 210psi on all 4 cylinders. Not bad for old rings.
As far as clutches go, I'm going to get a local clutch shop to rebuild mine from now on. They're cheaper and far better quality than the shelf parts available online or from parts houses. But to answer the question, I've never used a Luk clutch, but have used two oem replacement clutches from Advance Auto when they were doing their 20% off and free shipping deal. Those clutches have worked flawlessly, and have held up to my lead foot driving.
