- Joined
- Dec 30, 2024
- Messages
- 96
I run a highly modified 091 VW bus transaxle with Weddle parts in a sand car with a supercharged Ecotec engine. I chew up ring and pinions, bearings or gears pretty fast. At least once a year. Usually the pinion bearing or main shaft bearings go first. Is there a best addative or gear oil I can run? Last time I put in a bottle of Lucas ZDDP engine break in addative but have no idea if that works in a transmission. It has not blown yet but it’s due for an oil change and I was thinking either more ZDDP, a bottle of liquid molly or a best lube for the extreme conditions. Any suggestions welcome. It’s $1600 to $2800 every time it breaks plus it ruins the trip and it’s a lot of work to pull it out. What would you run in it?
