SandBlasting Aluminum
Ndx
IL
Hi Guys,
I Know that we have couple people's over here that know the topic ...
I arranged to have my aluminum wheels sand blasted with crushed glass .. Is that to abrasive ? I plan to have them Polished after ....
Thank you for Advize
Kris
Thank You Guys,
My self .. I have access to electric sander, orbital polisher ( with various PC and wool pads - lots of different
I hope that I will be able to pull it ... Any tips tom slick ..
stripping powder coat THICK! layer ...
Someone being carefull..
1 trying med glass bead
2 walnut shells this one I never tried but this might be a case.
That would be an option but was beating my brain if to or not thought I seen a set of wheels done chmically and became discolored pretty bad.
If they were discolored they used the wrong chemicals. I would call a competent plating shop and talk to them.
Try using an aerosol type of stripper. The brand that Home Depot sells, works on powder coat. I don't know why it is but I have found that only aerosol spray strippers are the only type of stripper that works on powder coating.
Hi ...
Tried Gasket Striper works so so ..
Bought Tal Strip II Air Craft Stripper same thing .. and stinks bad chemical poison here Im coming :P
professional chemical stripping to expensive ..
Thank You Guys...
